[Urgent] LabVIEW locked?! Help!!!!
Hello everyone,
I am currently working on a project related to nanomotion stage control using PCI-7344 and LabVIEW 6.1. I met a problem in using the Labview and it is extremely urgent (I have to make it work in 24hrs). I've never used LabVIEW 6.1 before, and it is really weird. The problem now is: I am not able to wire blocks and delete blocks in the block diagram. Though now I can right-click and then drag blocks from the function panel into the diagram, the blocks have no terminals, and there's no way for me to select the block I just draged in, and I cannot wire the blocks or delete them as well. If anybody knows how to solve this problem, please let me know!!!! I really appreciate it!!!
Thank you for your help!!!
Xiaofei
(3,438 Views)
Hi Xiaofei,
I have noticed similar behavior only when you copy and paste code from a higher version of LabVIEW to a lower version. If this is not what you are doing, did you try simply restarting LabVIEW? If none of this works, you should reinstall/repair your LabVIEW installation.
Jaidev
Senior Product Manager
(3,416 Views)
Duplicates post, solved at:
http://forums.ni.com/ni/board/message?board.id=170&thread.id=290670
(3,411 Views)
