Using Labview to control linear actuators
I have started a project to align some components together using some equipment that was left here from a previous project. Unfortunately I am completely new to Labview, but I have been watching the videos and playing around with it. I have a few people that may be able to support, but I thought it might be good to put a post up to see if anyone can help or if they have done something similar.
The transport equipment that we have includes:
  • A linear guide that contains a ball screw and is driven by a AC servo moto model AKM23C-ANBNC-01 (Danaher Motions).
  • A linear actuator that is placed onto the linear guide. Model is EC2-BK235-100-16B-60-MS6M-FT1M (Danaher
    Motion)
The control hardware includes:
  • PCI Motion Control Card (NI PCI 7344)
  • Universal Motion Interface (NI-UMI-7774)
  • Servo Drive Model (ServoStar S20360-VTS)
I have fully assembled all the hardware and plugged everything in. It just needs a program to run it all.
What I would like to do it make a control system that I can put in an X axis value and then put in a Y axis value so that it will move to whereever I tell it to. I will want to make a few adjustments to the Y value so I will need to keep changing that until I  happy with the position. Is this achieveable?
I'm hoping that it is very simple to achieve this, I have had a go but it gets a bit complicated for a first labview experience.
(6,303 Views)
If you are new to LabVIEW the best thing to do would be to look at the examples shipped with LabVIEW. You can find these by going to the LabVIEW example finder and searching for motion. Examples which act on the PCI 4340 series should work well as a starting point.
Thank you.
Nigel
(6,269 Views)
