setup compactRio to drive a 90V brushed motor
Hello:
I am trying to use the CompactRio in some testing and need to control and drive a 90V brushed motor from McMaster. The system will have 1 or 2 limit switches.
link to motor: http://www.mcmaster.com/#6470k52/=tu211p
I was wondering if anyone had suggesstions for setup? I was thinking of using the NI 9514 but there are no NI I/O modules that can output the 90V to drive the motor.
Any input or suggesstions would be appreciated.
(5,394 Views)
Hi tdra,
The 9514 is not supposed to be used to drive a motor but instead interface with the drive. You would first need a drive which would connect to your motor and then a connect the 9514 with your motor. NI does not currently have drives for brushed motors at the moment. So you can find a third party drive to interface with your motor and then connect that drive to the 9514.
Here is a setup of a system for a brushless motor, but your system should be similar:
http://www.ni.com/pdf/manuals/375516b.pdf#page=3
Paolo F.
(5,374 Views)
@FuManWho
Great, that is what I was thinking for the setup but glad to hear it confirmed. Thanks Paolo!
(5,350 Views)
