Using user-defined naming convention for multi-axis machines
Are the user-defined naming conventions for motion axes setup in MAX available in LabView (ie, if axis 3 is renamed "rotary stage" in MAX, can I reference the motion axis as "rotary stage" in LabView instead of "Axis 3")?  This would make keeping tracking of axes in a multi-axis, multi-vector space system much simpler.  Any thoughts?
Message Edited by Tea on 11-21-2005 11:54 AM
(3,103 Views)
Tea,
"Are the user-defined naming conventions for motion axes setup in MAX available in LabView (ie, if axis 3 is renamed "rotary stage" in MAX, can I reference the motion axis as "rotary stage" in LabView instead of "Axis 3")?"
Currently you cannot reference your access by the user defined named created in MAX.
Lorne Hengst
Application Engineer
(3,090 Views)
