step motor control direction and step
I need to send two signs one for the step and other for the direction. the sign for the step needs to have a certain frequency                                             scheme
the problem is when the frequency is larger than 5000  what is incorrect  I use a board 6023E thank you
(3,472 Views)
here is the screenshoot    http://ftp.ua.pt/incoming/marcolab/
(3,465 Views)
Puplicate Dost:
http://forums.ni.com/ni/board/message?board.id=170&message.id=153180
(3,458 Views)
