08-03-2009 01:10 PM
08-04-2009 09:55 AM
Hey LIBS,
Unfortunately, I am not familiar with the Thorlabs motor controller or its software's ActiveX interface. When you created the ActiveX window in LabVIEW, were you able to control your motor? Since the control of you motor is all done through ActiveX, the only way to get a device reference would be through the ActiveX interface. You will want to check the properties and methods associated with your Thorlabs ActiveX control to see if there is such a device reference available.
