What is error number -4470 returned by Flexmotion command mean
The error is returned from the first Flex_config_axis. The other commands return 0. - Thanks in advance
FlexStatus = flex_initialize_controller(PCI7344, 0);
FlexStatus = flex_config_axis (PCI7344, 0, 0, NIMC_STEP_OUTPUT3, 0, SlideMotorAxis); // Slide Motor Axis
FlexStatus = flex_config_axis (PCI7344, 0, 0, NIMC_STEP_OUTPUT2, 0, FeedMotorAxis); // Feed Motor Axis
(3,368 Views)
It is really odd since that error code is not specified in the error database, however I can suggest to you to try out the following:
1. Use the resources when calling a function, for example instead of PCI7344 send 0x01 (if board ID is 1), or instead of Step Output 1 send 0x41, makes sense?
2. Make sure FlexStatus is declared as i32.
3. Axes should be disable when configuring them.
4. Check the Software Reference Manual since I don't believe 0 is valid for Axis.
Good luck!
Nestor.
Nestor
(3,368 Views)
Thanks, Nester. For a reason I can't explain now I declared FlexStatus as short instead of i32, so the bogus return value was the result of the overflow. Sometimes problems are the reasult of simple errors.
(3,368 Views)
You're welcome, I'm glad is working now... good luck on your application.
Nestor.
Nestor
(3,368 Views)
