error code -70001
when I run onboard program sequence with other onboard program, my 7344 card return error code -70001
this sequence is:
-Begin Program storage.flx
Program(3)
-Run Program.flx
Program(1)
-Wait on Condition.flx
Ressource (Program 1)
Condition Code(Program Complete)
-Run Program.flx
Program(2)
Ressource (Program 2)
-Load Program Delay.flx
-End Program Storage.flx
Program(3)
-Run Program.flx
Program(3)
I used:
Win 2000
PCI-7344
FlexmotionFirmware version 5.20.000X
and LabView 6i
(3,649 Views)
Have you tried the onboard examples, http://search.ni.com/query.html?col=alldocs&layout=Example&qp=ContentType:Example&qt=onboard+7344+labview, do they behave the same.
The following KB, http://digital.ni.com/public.nsf/websearch/AC05B6F401633E6F862568080049A06D?OpenDocument, talks about which VIs can execute onboard and which VIs can only execute on the host?
(3,649 Views)
When I start program 1 and 2 individually in the Host, there is no problem, it is when I start this program in the sequence in third onboard program that there is a error -70001. And in this third program I don't used a Host Function
(3,649 Views)
