Wheel Encoder, Tachometer model & noise?
Hi all,
I am looking for mathematical models that represent the state of a wheel encoder and a tachometer.
From that, and the underlying physics of these devices, I'll characterize the noise for each.
Example: for a GPS module, the state vector x can be represented as x=[ position    velocity    clock_bias]'
and the model can be written as
x_k+1 = A*x_k + noise           with A some square matrix that involves angular velocity, gravity vector etc.
I'm not sure where to get that type of basic info. I tried looking up datasheets and IEEEXplore, to no avail.
If somebody could give me some pointers, that would be very appreciated.
Thank you!
Nicolas
(5,898 Views)
You can look for documents from System models or Automatic Control; there you can find some information about mathematic models. You can try with an empiric model too; you can find this information in Linear System Analysis’s literature. Regarding to LabVIEW, you can take a look for LabVIEW PID and Fuzzy Logic Toolkit (check the link for more information).
(5,879 Views)
