10-11-2012 10:17 AM
Hi all,
I am looking for mathematical models that represent the state of a wheel encoder and a tachometer.
From that, and the underlying physics of these devices, I'll characterize the noise for each.
Example: for a GPS module, the state vector x can be represented as x=[ position velocity clock_bias]'
and the model can be written as
x_k+1 = A*x_k + noise with A some square matrix that involves angular velocity, gravity vector etc.
I'm not sure where to get that type of basic info. I tried looking up datasheets and IEEEXplore, to no avail.
If somebody could give me some pointers, that would be very appreciated.
Thank you!
Nicolas
10-12-2012 01:18 PM
You can look for documents from System models or Automatic Control; there you can find some information about mathematic models. You can try with an empiric model too; you can find this information in Linear System Analysis’s literature. Regarding to LabVIEW, you can take a look for LabVIEW PID and Fuzzy Logic Toolkit (check the link for more information).
