03-14-2005 07:13 AM
03-14-2005
08:10 AM
- last edited on
07-10-2025
05:24 PM
by
Content Cleaner
NI-Motion 6.1.5 only supports the new 73xx series motion control boards. The PCI-FlexMotion-6C is obsolete but you still should be able to use it in your setup with the FlexMotion 5.1.1 driver software.
You also should install the 5.1.1f5 patch.
Please make sure that you uninstall NI-Motion 6.1.5 before you reinstall the old driver.
Jochen Klier
National Instruments Germany
03-15-2005 07:11 AM
03-15-2005 07:53 AM
03-15-2005 08:08 AM
03-24-2005 04:23 AM
11-30-2011 08:36 AM
Hi there,
Does anybody know where I can find NI-Motion 5.1.1f5 for an old Flexmotion-6C PCI? Too bad bad that none of the newer versions doesn't support it...
Thank you!
11-30-2011 05:34 PM
Hi zbo,
Please check your private messages.
12-01-2011 06:21 AM
Hi Paul,
Thank you! Installation worked like a charm, no lemons or other "hey" signs, both in WinXP and Windows7 (dual boot computer).
Now, I know I'm new, but can I use this card as a DAQ card? Is there a link somewhere with DAQmx? Those 6 DACs 16 bits look so good...
For example, I want to generate a precision sinusoidal/square signal to analize it further with PCI-6220, can I?
Best regards!
12-01-2011 10:16 AM
Hi zbo,
Unfortunately, you can't use the motion board as a daq card. You can use an unmapped DAC on the motion board to generate a signal, but it will be software timed. I don't think you could generate a square wave at any reasonable frequency. You might be able to generate a low frequency sine wave (< 50Hz), but it will be subject to the jitter of your PC. In the newer NI Motion drivers there is a Load DAC.flx VI that you can use to load the DAC in software. There is probably something similar in NI Motion 5.1 if you want to try to use the DAC.
In short, DAQmx will not work with the motion card and you shouldn't use the motion card to substituate as a DAQ board. You can certainly try it for yourself, though.
