03-16-2007 12:53 PM
03-16-2007 01:19 PM
03-16-2007 01:19 PM
What manufacturer and model? Application and always on and under load?
Depending on what you are doing, yes, it could possibly harm it or dramatically shorten it's life.
03-16-2007 01:34 PM
It a igarinfo@igusa.com igarashi no 33Gn2732,12 v dc gear motor, it will be used in a stop and go - aplication
| No Load | Max Efficiency | Stall | ||||||||||||
| Voltage | Speed | Current | Speed | Torque | Current | Output | Eff. | Torque | Current | |||||
| V | RPM | A | RPM | mN-m | g-cm | oz-in | A | W | % | mN-m | g-cm | oz-in | A | |
| 37GN2742-133-GF-3 | 12 | 85 | 0.079 | 67.5 | 165 | 1683 | 23.4 | 0.29 | 1.17 | 34.2 | 800 | 8170 | 114 | 1.08 |
03-16-2007 05:14 PM
drsantos:
The model number in your post does not match the data in the table. I briefly went to igusa's site to see if they had more info regarding voltage range, but did not see anything relevant. It may be best if you contacted igusa directly.
