05-29-2010 08:49 PM
06-01-2010 05:48 AM
06-01-2010 11:18 AM
06-01-2010 12:23 PM
06-01-2010 12:39 PM
I have the flex drives. This is an upgrade job from a very old PLC setup. I didnt think I needed the flex drives since Labview had a PCI card. I will still need help wiring it up if anyone has any suggestions.
06-15-2010 10:00 AM
is there a driver for this flex drive? Also does anyone have a wiring diagram to go from the UMI-7772 to the
Baldor Flex Drive?
06-15-2010 11:03 AM
The real Macgyver wouldn't ask these kinds of questions!
You can run the Flex drive in analog torque, analog velocity, or step and direction modes. If you have a motion controller, then I would recommend using analog torque mode. Here are some generic instructions, since I am not an NI motion expert. You will need to connect the simulated encoder output of the drive to the encoder input of the UMI. You will not need to connect the encoder power lines of the UMI. You will need to connect the analog reference output of the UMI to the analog input of the Flex. The only other connections you really need are amp enable and amp fault. If I recall, you can set up a relay output on the Flex for the amp fault, but I think the amp enable signal is 24VDC. I am not sure what signal levels the UMI uses. Please read through tutorials on motion controls, and the manuals for your products, and get back to us with some specific questions.
06-15-2010 02:24 PM - edited 06-15-2010 02:25 PM
Thanks for the help
