[basic] the scope of motion control in LV
I am a very beginner in motor control part.
Very recently, some motor need to use some proper control board in control unit or PC.
If so, what is the scope of the motion control driver (library) in LabVIEW developement version?
Some restricted motor type?
What other instrument should I prepare to use the driver?
What's the difference between this type(PC or control board) and NI motion controller?
Any materials for beginner should be welcomed.
(3,685 Views)
For getting started with NI Motion Control I recommend this website. Here you will find tutorials, webcasts, selection guides and much more.
In general NI Motion solutions are not limited to specific motor types or applications. Depending on your application requirements you can select between motion control plugin-boards or software defined systems based on real-time hardware and/or FPGA technology.
Please have a look at our web resources first and post any specific questions to the forum.
Jochen Klier
(3,664 Views)
