binary string to number
Is there an easy way to translate binary string to decimal number .
i.e
input "0000100"
output : 4
input : 10000000
output : 128
Thanks for your time
(13,337 Views)
Is the string always 8 characters (bits) long?
Are you using LabVIEW?
(13,334 Views)
Another question - Binary numbers can be interpreted in two ways:
- always positive
- positive or negative
which situation applies in your case?
(13,333 Views)
The length is always 8 chracter and always with positive meaning.
I know i can use a simple case sequence with all the possibilities , but i was wonder if LabView can offer some built in functions .
Asaf
(13,330 Views)
Thanks , it is just what i needed .
Asaf
(13,318 Views)
