blend move with the same interval time
Is there a way to make blend move with the same interval time between moves? My mechanical system can't support the target accelerations if I try to make the move with contour motion.Thank you.
(3,331 Views)
Yes. If you use a blend factor of greater than zero, the motion controller automatically calculates the corresponding delay (in ms) as soon as the first move is complete. For example, a blend factor of 10 sets a 10 ms delay between each move.
I hope this helps. Let me know if you have further questions about this matter.
Yusuf C.
Applicatons Engineering
(3,331 Views)
