reading dio port data in pci 7344
I have few swithces read through the DIO lines. I need to get these inputs really quickly. Is there any way to do this like the high speed capture.
(3,054 Views)
The digital ports available on the NI motion boards are generally designed for static digital I/O operations i.e. low speed. An example of this might be the periodic checking of the state (Low/High) of a mechanical switch input. You mention that you need to get these inputs really quickly - could you define "really quickly" in terms of readings/second?
The software approach for reading these ports is simply to call the appropriate function/VI and the rate at which you could perform this operation in a loop will be dependent on the other activities going on in your application, speed of PC etc. A simple application that only reads the digital port in a loop could give you a maximum reading rate, but you will need to understand that other bits of your applicatio
n will have an impact on the reading rate.
There are a number of trigger inputs available on the 7344 motion control board. Depending on the nature/use of the switches you are referring to, it may be possible to consider using other functionality on the board to help your application. I would be happy to help by offering advice if you could provide a bit more information about the scope of the application you are developing.
Jeremy
(3,054 Views)
