configuring breakpoints
Hello, is there a way to disable the "feature," which causes LabVIEW to switch windows when a breakpoint is hit during execution (in effect, jumping to the block diagram of the VI that the breakpoint is located in)?  I can see how this would be useful, but it's often annoying, as I keep having to do alt-tabs back and forth between VIs or back to the front panel of the same VI.  I apologize in advance if this has already been asked (at quick glance, I don't see that it has).  Thanks.
(3,353 Views)
whoops, i just realized i posted this in the totally wrong forum... sorry!
(3,351 Views)
