08-21-2006 05:47 AM
08-21-2006 06:14 AM
08-21-2006
06:16 AM
- last edited on
03-05-2025
02:06 PM
by
Content Cleaner
The 7344 supports four motors (servo or stepper) simultaneously. As long as you are using stepper motors you could also think of switching the motion signals with an external relay multiplexer to more motors but then the multiplexed motors couldn't run in parallel. Depending on your application this would mean that you would have to switch a lot of signals (step, direction, limit switches, inhibt outputs,...) and I don't think that this would make much sense. With servo motors this approach wouldn't work anyway as the control loop would be interrupted.
If you want to control more than four motors you better should use another PCI-7340 (2 or 4 axes) or a PCI-7350 (2, 4, 6 or 8 axes).
Jochen Klier
National Instruments Germany
08-21-2006 06:20 AM
08-21-2006 06:32 AM
