status error value of -78007 not listed in NiMotion error codes for PCI 7334
MAX is able to  reset and intialize the 7334 but call to flex_initialize_controller in my Borland C++ returns a -78007 as an error code which is not listed in the error code tables - .
does anyone know what this code means?
(3,129 Views)
Never mind - found the answer in an earlier post. I'm trying to access the default MAX settings via a settingsName of NULL for default - Must not be setting it up correctly
(3,126 Views)
