convert acceleration from RPsec/sec to mm/sec2 for servo
Hi all of you
I am using the accelartion VI from for the motion
One input is the acceleartion in RPsec/sec how can I convert this unit in a real acceleration unit mm/sec2
Any help
Jürgen
(3,775 Views)
Jürgen,
RP/sec^2 means Revolutions per second^2. So the only thing that you have to do is to multiply this value with the pitch of your mechanical system [mm/revolution] (how many mm does your stage move per revolution). Depending on your system you will have also to take into account the gear reatio of a gearing box.
I hope that helps,
Jochen Klier
National Instruments Germany
(3,770 Views)
Danke Herr Klier
Jürgen Buhrz
GKSS
(3,767 Views)
