flex motion finding home does not set HomeFound
I use the flex_find_reference to find home. I then use flex_check_reference to determine when home is found, but the found parameter does not go true, even though the flex_read_input_status and the flex_read_home_input_status calls show the home switch on.
(3,165 Views)
Have you enabled the forward, reverse, and home limits for your motion controller? The find reference settings for your system may need to be modified. A tutorial on how to do this can be found at:
Find Reference Settings for Motion Controllers
http://zone.ni.com/devzone/conceptd.nsf/webmain/3F42374A9CF5C8BA86256B9D0081A37B?opendocument
Have you tried using any of the shipping examples for NI-Motion? For LabVIEW, they can be found by navigating to:
C:\Program Files\National Instruments\LabVIEW 7.1\examples\Motion\FlexMotion
Examples for Visual C++ or Visual Basic can be found by navigating to:
C:\Program Files\National Instruments\NI-Motion\FlexMotion\Examples
Try looking at the find reference shipping examples found in those folders.
Scott R.
Scott Romine
Course Development Engineer
(3,165 Views)
