home switch from panasonic
hi,
 can someone please advice me on whether this Limit switch from Panasonic is suitable for my UMI 7764 and PXI 7332? i cant figure out which Information is relevant for my choice? here is the data sheet:
http://www.panasonic-electric-works.com/peweu/en/downloads/ds_63030_2700_en_az7.pdf
(4,140 Views)
Kenzi,
as this is a mechanical home switch, it will work with the UMI 7764. Please refer to the UMI's manual for the wiring diagram and to the 7332's manual for information about the limit switch input circuitry.
In short: just connect the switch between the switch input of the UMI and GND. The switch input is pulled up internally on the 7332 to +5 V, so no external power connection is required.
Kind regards,
Jochen Klier
(4,134 Views)
