07-02-2010 10:10 PM
Hi, Guys,
I try to accumulate all the past position error to feedback the motion loop. I can use this formula node in LV8.5 and 9.0. I cannot use it in LV8,0 or 8.2? In my lab pc, it's LV 8.0 or8.2. I cannot wire back the output sum to input sum. How can I resolve the problem in LV 8.0? The input variable is acquired by Machine vision Loop in real time.
Thank you!
07-05-2010 04:18 AM
Guangli,
the feedback node was introduced with LabVIEW 8.5. In older LabVIEW versions you should use a shift register.
Kind regards,
Jochen Klier
07-05-2010 03:27 PM
Thank you! Actually, we don't have to use formula node inside while loop. A plus sign is enough. How can I do if the control variable is outside while loop.
