How can I accumulate all thevalues of past error? I can do it in LAV 8.5. Cannot in Lv8.0.
Hi, Guys,
I try to accumulate all the past position error to feedback the motion loop. I can use this formula node in LV8.5 and 9.0. I cannot use it in LV8,0 or 8.2? In my lab pc, it's LV 8.0 or8.2. I cannot wire back the output sum to input sum. How can I resolve the problem in LV 8.0? The input variable is acquired by Machine vision Loop in real time.
Thank you!
18067i6173F629B8410A58
(4,242 Views)
Guangli,
the feedback node was introduced with LabVIEW 8.5. In older LabVIEW versions you should use a shift register.
18113i726722A1D2BD8CC0
Kind regards,
Jochen Klier
(4,228 Views)
Thank you! Actually, we don't have to use formula node inside while loop. A plus sign is enough. How can I do if the control variable is outside while loop.
(4,219 Views)
