home switch
During the test of stepping motor's movement, I've found the trouble thing that even though home switch was inactive state setting in MAX, motors often stoped at near home switch. I want to natually move motors to the target point neglecting home swich just keeping the FWD/BWD limits. If one knows the answer to solve my proble, your help would be appreciated.
Thanks !!!
(3,017 Views)
I tried to reproduce the problem with NI-Motion 6.0 but wasn't successful. If you have an earlier version of the driver go ahead and upgrade to version 6.0 (ni.com/downloads). If this doesn't help there might be a problem with your signal connections. If you still have problems let me know.
Yusuf C.
Applications Engineering
(3,017 Views)
