how to connect the UMI-7764 to a geared motor
Please, I have simply to connect a geared motor to the UMI-7764 thru an L293D driver.
Please, could you tell me which outputs of the UMI-7764 do I have to connect to the driver ?
Thank you.
(2,971 Views)
You'll need to refer to the documentation for the L293D driver to determine which lines it need attached. For servo motors you typically atach the Analog Out line as well as the Encoder feed back lines from the UMI. For steppers, you need to at least wire the step and direction lines to your drive. I recommend taking a look at the 7764 user manual as well for help with wiring.
(2,971 Views)
