how can i control the motor movement of stepper motor using a NI PXI 7330
Good day to all,
i'm a newbie in programming in motion control of NI. I just want to ask if how can i control the clockwise and counter-clockwise rotation of a stepper motor using NI PXI 7330 module. all i can do is the counter-clockwise rotation using the example vi (Simple one-axis move.vi) found in the examples of LabView 2009.
Message 1 of 16
(6,297 Views)
Tikoy,
the rotation direction depends on the operation mode and the move parameters:
  • In relative position mode the rotation direction is determined by the sign of the target position.
  • In absolute position mode the rotation direction is determined by the sign of the difference of target position - current position.
  • In velocity mode the rotation directionis determined by the sign of the velocity parameter.
For more information please refer to the online help.
I hope that helps,
Jochen Klier
Message 2 of 16
(6,294 Views)
Good day Sir Jochen,
thank you for the advice. i'll put a negative sign in the target position.
thanks
Message 3 of 16
(6,291 Views)
i tried putting a negative sign on the target position but still the rotation of the stepper didn't not changed . do i need to add more wiring to the UMI because i only wired the 5V , CW and the CCW port
thanks
Message 4 of 16
(6,277 Views)
Hi Tikoy,
is there a chance, that you have configured the 7330 to output a step/direction signal, while your drive expects a CW/CCW signal?
You can change this setting in MAX:
I hope that helps,
Jochen
Message 5 of 16
(6,267 Views)
Thanks for the help. Your advise works in my program ... Super Thank you for the advice.
Best regards
Message 6 of 16
(6,226 Views)
Good day to all,
Right now I'm troubled why my motor still moves even if it reach the limit sensor that i've intalled in my project. I only wired the limit switch to the necessarry pinout of the UMI-7764 (forward and reverse). need help
Message 7 of 16
(6,199 Views)
Tikoy,
what type of limit switch sensor are you using and how did you wire itß What are your MAX settings regarding the limit switches?
Jochen
Message 8 of 16
(6,192 Views)
Good day SIr Jochen,
I am using two reed switch for the reverse and forward limit. I wired the signal wire of the reed switch to the limit ports(forward and reverse Limit) and its ground to the digital ground of the UMI-7764.
the attachment below is the my max configuration about limit switches
Message 9 of 16
(6,188 Views)
Good day Jochen,
I'm using two reed switches I've connected the signal wire of these switches to the forward and reverse limit of the UMI-7764. their ground wire are connected to the digital gnd of the UMI 7764.
the attachment below is the MAX setting regarding the limit switches.
thanks
Message 10 of 16
(6,188 Views)
