12-07-2010 03:41 AM
Good day to all,
i'm a newbie in programming in motion control of NI. I just want to ask if how can i control the clockwise and counter-clockwise rotation of a stepper motor using NI PXI 7330 module. all i can do is the counter-clockwise rotation using the example vi (Simple one-axis move.vi) found in the examples of LabView 2009.
12-07-2010 03:55 AM
Tikoy,
the rotation direction depends on the operation mode and the move parameters:
For more information please refer to the online help.
I hope that helps,
Jochen Klier
12-07-2010 04:02 AM
Good day Sir Jochen,
thank you for the advice. i'll put a negative sign in the target position.
thanks
12-07-2010 08:35 PM
i tried putting a negative sign on the target position but still the rotation of the stepper didn't not changed . do i need to add more wiring to the UMI because i only wired the 5V , CW and the CCW port
thanks
12-08-2010 02:10 AM - edited 12-08-2010 02:10 AM
Hi Tikoy,
is there a chance, that you have configured the 7330 to output a step/direction signal, while your drive expects a CW/CCW signal?
You can change this setting in MAX:
I hope that helps,
Jochen
12-09-2010 02:10 AM
Thanks for the help. Your advise works in my program ... Super Thank you for the advice.
Best regards
12-13-2010 01:22 AM
Good day to all,
Right now I'm troubled why my motor still moves even if it reach the limit sensor that i've intalled in my project. I only wired the limit switch to the necessarry pinout of the UMI-7764 (forward and reverse). need help
12-13-2010 02:30 AM
Tikoy,
what type of limit switch sensor are you using and how did you wire itß What are your MAX settings regarding the limit switches?
Jochen
12-13-2010 03:32 AM
Good day SIr Jochen,
I am using two reed switch for the reverse and forward limit. I wired the signal wire of the reed switch to the limit ports(forward and reverse Limit) and its ground to the digital ground of the UMI-7764.
the attachment below is the my max configuration about limit switches
12-13-2010 03:37 AM
Good day Jochen,
I'm using two reed switches I've connected the signal wire of these switches to the forward and reverse limit of the UMI-7764. their ground wire are connected to the digital gnd of the UMI 7764.
the attachment below is the MAX setting regarding the limit switches.
thanks
