Motion Control and Motor Drives
i want to use a current card (PCI, around 200mA) to drive a servo valve
   I want to use a current card (PCI) to drive a servo valve in the hydraulic actuator. The current requirement is around 200mA.
   What choice do I have?
(3,301 Views)
Hi Charlie,
I don't know of any NI products that will source that much current.  You will probably need a servo drive with an external power supply to do this.  You can use this in conjunction with any of our motion controllers, i.e. 7330-, 7340-, and 7350-series boards.
The servo drive acts as an amplifier for the signal generated by the motion controller.
Brandon M.
Applications Engineer
(3,265 Views)
