limit inputs of PCI-7334 can't be disabled
I'm using LV 7.0 and FlexMotion 6.0 with a PCI-7334 card with a stepper motor.
Every time when I try to find the home position of that motor, the flex VIs drive the motor but it ends always with the error -70119 (i.e. the move can't done because the limit input in the desired direction is active).
It's not possible to disable both the limit and home inputs with the corresponding VIs "enable limits.flx" and "enable home inputs.flx".
Can somebody help me?
(3,194 Views)
Please upgrade your NI-Motion driver to version 6.1.2:
http://digital.ni.com/softlib.nsf/websearch/57FA88D0FEC8439F86256C740024CE88?opendocument&node=132060_US
I did some tests with this version and the disabling of the switches just works fine.
Jochen Klier
Applications Engineering Group Leader
National Instruments Germany GmbH
(3,194 Views)
