motion assistant msvcr90.dll
I was trying to run an EXE that I built that uses Motion Assistant to build contour profiles.  I was able to run this last week without this problem occuring:
I am getting an access violation from LV 11.0 when it is trying to use MSVCR90.dll
I have never seen this issue whent using NI Motion or boards before.  When I went to reboot Windows 7 (64) wanted to do an update install.
I am running LabVIEW 2011 SP1 I believe.
Anyone know what could be causing this?
Upon reboot I will try again and see what the Windows update installed.
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(5,553 Views)
Hi Ryan,
I'm not sure what might be causing this, but here are a few steps we can take to identify the underlying issue:
1) Is LabVIEW generating a crash log file when the access violation occurs? If so can you post it here?
2) What version of NI-Motion is referenced by the EXE?
3) MSVCR90.dll does not appear to be related to NI-Motion. Is the EXE performing any other notable functions? Particularly in calling external code?
4) Was the EXE built on a 64 bit system? Does the same error occur on the development (or any other system)?
Sorry for the long list of questions, but hopefully they will help us narrow down the cause of the crash.
(5,543 Views)
