motion control using MCU 28stage controller of Zeiss
Does any one know how to control Z axis motion using MCu 28 stage controller of Zeiss, with/without LabVIEW. I am working in the windows environment. Any suggestions will be appreciated.
Deepak
(4,833 Views)
Hello Deepak,
The MCu 28 stage controller by Zeiss should have a driver that will control it. The driver will be developed and managed by Zeiss.
- If the driver is a .dll that you can make function calls to, then LabVIEW has the ability to make calls to the .dll.
- A .dll can be accessed by most programming environments (C, C++, Visual Basic... & LabVIEW).
If you do not have access to the driver for the controller, then you will need to follow up with Zeiss.
If you are wanting a significantly easier motion controller to integrate into your application, National Instruments offers a variety of Motion Controllers (www.ni.com/motion).
- If you have any specific questions regarding upgrading or making .dll calls from LabVIEW, then please contact National Instruments
at 1800 IEEE 488.
(4,833 Views)
