03-24-2007 02:16 AM
03-24-2007 08:24 AM
03-26-2007 01:41 AM
03-27-2007 06:26 AM
03-27-2007 06:28 AM
03-27-2007 06:41 AM
03-28-2007 01:07 AM
03-28-2007 02:17 AM
03-28-2007 05:59 AM
Dear Mr.Jochen,
We are developing Antenna Control System (ACS) based on LabVIEW 8.2.platform using NI-7352 motion controller card, NI-6229 digital card and UMI 7774 opto-isolator interface card. The ACS is required to drive a Servo mechanism comprising of a servo motor SEM make (Rated speed of 6000 rpm) with a suitable servo power amplifier.
We have two different systems to be rotated at different speeds. One system is to be rotated at the rate of 1800 rpm and the other at 4000 rpm. These are the max velocities at which these systems are to be rotated. For a discussion on the problems we are facing we shall take the case where the max velocity at which the system is to be rotated is1800 rpm. Please find the following observations.
Case 1. kp=12, kd= 0, kv=0
When these values are loaded my system does not go more than 900rpm.
Case 2. kp=25, kd= 50, kv=0,Td=0
For these values my system does not go more than 1300rpm. Also I could observe jerky movements physically on the antenna movement.
Case 3. kp=30, kd= 60, kv=0, Td=0
At this point the system could go up to 1700rpm also. But the jerky movements have increased substantially.
Also the system comes to a halt if the velocity is set more than above values in each case after the max velocity in each case.
3. The antenna was driven by directly connecting the motor and power amplifier to it and observed the system rotating smoothly and to the rated speed without any jerks, which does rules out ant problems with the motor, power amplifier or the mechanical system.
We have the following to be addressed.
Please suggest ways to achieve the above. Please let us know the PID settings are correct or what modifications we need to carry out. At present we are setting these values based on our experience and we do not possess PID tool kit.
We have done quite a number of tests in tuning the motor and have an idea of what happens when kp or kd or ki is changed to some extent.
Look forward for your early response.
Vani, Engineer, Jisnu Communications Ltd.
03-29-2007 11:51 AM
