multi axes control
Hi Özgür,
I think you might need to better explain (maybe with a picture) what you want. You say you want to display all the values but at the same time you don't want to show all the values because it takes up too much room. If you want to show all the values, they will take up room on your front panel. If you are concerned with the amount of space used, you will have to either choose not to show certain values or use an indicator that allows you to scroll through the values (such as an array).
Message 11 of 11
(925 Views)
