stepper motor drives
I am developing a control system for the speed control of a gas turbine. So for that i need to change my present manual movement of the fuel valve to one by a stepper motor. The valve is very sensitive, so i need a high resolution stepper motor (100,00 steps per revolution). I have a NI CRIO and have a digital I/O module fit on the chasis. With the existing setup, i would like to know what is the best stepper motor i can get in the market with least modifications to my current setup. If such a thing is not available, then what is the next best choice. Can anyone please help me out on this.
Umesh
(4,200 Views)
Hi Umesh,
could you please provide some more information? First I feel a bit uncertain by the resolution that you are looking for? Do you mean 10,000 steps per revolution or 100,000 (with a missing zero at the end)?
If it's 10,000 steps/rev, you could use a standard stepper motor (200 steps/rev) with x50 microstepping. If it's 100,000 you definitely will need a gear box. In general I would also recommend a gear box if you need 10,000 steps/rev, as x50 microstepping is already a quite high value, resulting in reduced accuracy (steps are not evenly distributed anymore).
Some other questions:
  • Could you please provide information about the required velocity and acceleration values?
  • What about the inertia of your valve? Any idea about motor sizing?
  • Which cRIO digital I/O module are you using?
  • Are you using NI Softmotion?
  • Have you thought about using cRIO drive interface modules (makes programming much faster and easier)?
  • Have you already decided which power drive to use?
Kind regards
Jochen Klier
(4,199 Views)
I am using NI 9401 digital i/o module. I donot have specs relating to velocity and acceleration of the motor. I am not using NI soft motion.
(4,165 Views)
Hi Umesh,
for a proper motor sizing all the information that I have requested is really essential. What about the resolution (10.000 or 100.000 steps/rev)? What about the required motor power and the load's inertia?
I'm sorry, but I really can't help you without knowing these specifics.
Jochen
(4,144 Views)
Hello Umesh,
Here's a site you might find useful for deciding on which motor/drive to use for your application: http://in.farnell.com.
Vaibhav.
(4,117 Views)
