Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
one step distance
one step distance
connector
01-01-2003
09:09 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
why the distances that the motor moved for one step under Flexmotion control and MAX are different? Am I wrong with configuration?
0
Kudos
Message
1
of 2
(3,098 Views)
Reply
Re: one step distance
Brent_R
Active Participant
01-02-2003
09:43 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
They should work exactly the same. Maybe one is set to absolute position mode and the other is set to relative. Make sure the modes are the same.
Brent R.
Kudos
Message
2
of 2
(3,098 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
