pci 7344
Dear Mr Scott R,
NI Application Engineer,
You already answered my question on the impossibility of implement fuzzy logic control on PCI 7344 card.
I would appreciate if you can suggest me any research that I could do on this system which involve 3 axes motion -using all ac servo motor (automated storage and retrieval system) - I have 3.5 months only to complete my thesis.
maybe anything related to PID or motion. You suggestion (also from others) very very much appreciated. Maybe to offline simulation.
Thank you.
SADIAH
(4,051 Views)
Hi Sadiah,
I'd suggest using NI SoftMotion Development Modulke for LabVIEW along with the control design toolset.
Give us a call some time and we can get you all hooked up with what you will need
Regards
Dan Q
(4,041 Views)
I am in Malaysia now. To be detailed, the motion card I used for xyz automated storage and retirieval system with 3 servo motor. My intention is to compare between PID and fuzzy controller on that system. I am really constraint with the budget and time especially. Only 3.5 months only. Expected to get outcome by March. Could I do the programming offline. Without using the card?
TQ.
(4,035 Views)
TQ.
(4,039 Views)
TQ -
If you install NI-Motion drivers (available on our website: http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BE60070AC71?opendocument&node=132060_US), you can add a 'virtual' 7344 motion board in Measurement and Automation Explorer. This will allow you to build NI Soft Motion or LabVIEW motion programs without actually having your PCI-7344 board installed. There are also a number of motion example programs available to get you started. (the following is how to do a ‘Three Axis Vector Move’: http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3DF9956A4E034080020E74861&p_node=DZ52480&p_source=External
Good luck with your project!
(4,013 Views)
