post
Hi there,
I need to control hp 34970a through serial port. RS232 cable connected. When I ran "HP34970A Comm interface.vi", I can hear beep and it showed "RMT". But Open/close commands don't work at all. and any read will return error message. "write" command has no error message.
Hai
(3,601 Views)
Please refer to this thread.
(3,594 Views)
Hi Hai,
Can you post a Spy Capture of your communication? You other post mentioned some “strange strings” that LabVIEW returned and a Spy Capture would help identify that. Thanks.
Matt
Matt
(3,572 Views)
Matt,
It was solved. in the resource name I was using com1 instead of ASRL1::INSTRU.
It works perfectly now.
Thank you very much
Hai
(3,562 Views)
