Home
Community
Discussion Forums
Most Active Hardware Boards
Motion Control and Motor Drives
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
problem on control the bushless motors by motion assistant
ivan_chiu
Member
02-25-2004
12:09 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I have used the MAX to control the motors sucessfully, but I cant use the motion assistant to control the motors. Any special setting or config. that I need to do?
0
Kudos
Message
1
of 2
(2,968 Views)
Reply
Re: problem on control the bushless motors by motion assistant
algames
NI Employee (retired)
05-22-2004
07:51 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Are you initializing your board before running a move in Motion Assistant? Does Motion Assistant report any errors when trying to run these moves?
0
Kudos
Message
2
of 2
(2,968 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
