I use the PXI 7344 card from NI and I have a problem, whit this card. If i initizialize this card under CVI it brings a warning, that i dont understand (CODE 4294897293). In MAX the CODE is -70003, if I inizialise the card.
In my program ( I write it in CVI) the card starts using the engine, but I have make only configurations and tell him befor, that the engine doesnt start.
A friend tell me, that MAX makes changes, withou ma known, but I think that isn´t so... Wirte MAX the coniguration of my card also in the DAQ-file or write MAX the configuration into the memory of the card?
The card run in a system with a powerunit (MESA 1/1A-220/17-W-T-B5). can that device "knock out" my card?
I tested the
analog output of the 7344. I find out, that the card set the output to 10V, but I donst´n say that to the card! I say u =0 und u/s=0...
My state is at the moment, that I disable the analog output for the card in MAX. Start my application to make my settings and set the analog outupt in MAX of enabled if the config ist ready.
but that is no solve for my problem! I can not change the configuration manualy if the system must be restarted...
what can I do?
