really need help (motor control using labview)
hi all readers,
im new beginner. really need help for my project. i've been assigned to monitor/control motor using labview 8.5 (using NI DAQmx). the problem is, the techinician told me that i cant use 3phase motor with this card. things that i need to displayed using labview is :
  1. torque
  2. power
  3. current
  4. voltage
  5. speed
really appreciated if readers can help me with this:
  • wut type of motor shud i use that compatible with NI DAQmx
thanks a lot.
Message 1 of 13
(7,131 Views)
Hi fauziana,
NI data acquisition devices are primarily designed to take measurements, so it's a good idea to measure the signals that you have mentioned with a DAQ device.
You also can use DAQ devices for control tasks, but for reliable and deterministic control behavioryou typically need to use a real-time operating system (not Windows!). If you want to learn more about the pros and cons of using DAQ devices for motion control tasks, please refer to these threads. Still for standard motion control tasks it's much more efficient in terms of development time, to use a dedicated motion control device for the motion control part of your application.
In general the control part is independant from the motor type, as these devices only generate control signals (+/- 10 V). There are many power drives available, that accept this type of control signal and you should select your motor according to the requirements of your application.
For a more detailed system consulting, please contact your local NI branch. To select the products that fit best to your application requirements a face to face discussion is much more efficient than a discussion forum thread, because there are a lot of parameters that need to be taken into consideration. If you tell me in which country you are living, I can provide appropriate contact data to you.
Thanks and kind regards,
Jochen Klier
Message 2 of 13
(7,125 Views)
hi,
Thanks a lot to Jochen Klier for your fast reply. Really appreciate it. My home country is Malaysia. n my university is a user of National Instrument Labview.
Message 3 of 13
(7,116 Views)
hi Jochen,
i simplify my confusion to the simplest one. I want to control/monitor motor using labview8.5. n i just have NI DAQmx with me. the prob is i dont know wut type of motor i shud use in my application. i've already go through ur suggested site n i found that they are using different card.
thanks a lot
Message 4 of 13
(7,112 Views)
Fauziana,
to make it clear and simple: A DAQ device in a Windows environment is the wrong device in the wrong environment for motion control applications. You can waste a lot of time on developing an application based on that hardware, but there is a high chance for failure.
Here are the contact data for NI in Malaysia and I highly recommend to contact them for a more detailed consulting:
Tel: 1 800 887710
Fax: 603- 7955 2000
Virtual Instruments Sdn Bhd (a National Instruments Company)
Wisma Kemajuan Jalan 19/1
Suite L 2-1, Level 2 46300 Petaling Jaya
Selangor, Malaysia
Kind regards,
Jochen
Message 5 of 13
(7,110 Views)
hi Jochen,
Thanks a lot for your fast reply and useful info u gave. I surely will contact the NI here.
Best Regards,
Fauziana
Message 6 of 13
(7,104 Views)
  dear fauziana.
contact me 0172026450 . or add me at ym: skype_net7
undergraduate local student inspired to use LabView for final year project
nubies here need guidance.
Message 7 of 13
(7,032 Views)
Hello Everyone,
I would ultimately like to control an xy stage from ThorLabs .  What I would like to do is the following:
I would like the stage to do the following:
1) Move down 1cm
2) Move right 1 micron
3) Move up 1cm
4) Move right 1 mircon
5) Repeat steps 1-4 until stage has moved a total of 1cm across
6) Then have the stage move 1cm to the left
7) 1 micron down
8) One cm to the right
9) 1 micron down
10) repeat steps 6-10 until stage has moved a toral of 1 cm down
11) repeat steps 1-10 for 1000 layers
I am brand new to LabView and currently only have the program to run one motor with the Active X function provided by ThorLabs.
My current program is attached.
Does any one know of any existing programs which do something similar or would any one know how to construct this program?
Message 8 of 13
(6,761 Views)
I have same problems with you. I need stage X moving to right 5 mm and continue with stage Y moving down 5 mm. I need it controlled from VI, not from Thorlabs front panel. Any body can help me ?
Rahmat
Message 9 of 13
(5,723 Views)
I am doing the same too, But then I am operating two stages in Mercury Step, any idea for me to solve the problems for running two dimensional scan?
Message 10 of 13
(4,905 Views)
