stop motion
Hi Jochen,
Thanks for the reply.
I'm actually tryin to design a software controller panel to replace a physical controller which controls the movements of the needle. The physical controller's circuit board is custom made by this company which produces the needle, so i'm unable to get any information of its configuration and hardware details.
It does have a motion control interface which gets the physical controller's inputs and outputs at the needle as movements. I guess this interface is the motion controller hardware. Sadly, the hardware of this is also not available or rather not provided by the company.
I understand that by using a virtual motion controller, I cannot run a program and I will get some errors.
Since i do not have any relevant info of the hardware the motion interface uses, is there any other communication protocol that I can use to counter this problem like by an USB or something else ?
I've attached a document for you for your better understanding. Pls do look through it and give me your advice.
Please do help me out in this as I've no professional assistance to turn to.
Can I kindly request to communicate via email, because most of the time, I'm facing some server difficulties accessing to his forum. Thx for ur understanding.
my email add : singa611@hotmail.com
Thks N Rdgs
Titano
Message 11 of 11
(1,094 Views)
