Hey Nandkumar,
The velocity of a contoured move is not determined by the velocity parameter but by the distance between the position points in the contour array. Thus, in this case, the velocity parameter has no effect and flex_load_velocity_override() doesn't change the velocity of contoured moves. The velocity override command does work with straight line moves, arc moves, and other moves, just not with contouring moves, because the contour moves set their velocities in a different way. Please refer to the following discussion forum link
Using velocity override in absolute contouring mode for more information on why this function doesn't work with contouring moves. Also, in this discussion forum there is somewhat of a work around.
I hope this helps. Please let me know if you have any further questions on this. Thanks and have a great day.
DJ
