用NI9206在cDAQ中进行可重出发数据采集
19985iBC8F44F2AAB25D34
Hi
I am following the example: Acq&Graph Voltage-Int Clk-Retriggerable.vi by NI9206 in a cDAQ。The following errors occors:
Error -200452 occurred at Property Node DAQmx Trigger (arg 1) in Acq&Graph Voltage-Int Clk-Retriggerable.vi
Possible reason(s):
Specified property is not supported by the device or is not applicable to the task.
Property: Start.Retriggerable
Task Name: _unnamedTask<6D>
What is the problem?
Thank you
(3,230 Views)
(3,209 Views)
