0x80004005 when writing to a remote DB server
HI,
I have an labview application using continuous measurement of sensors which writes to a remote server via internet. Lately I am getting this error 0x80004005 and the recording stops which then needs manual restart when we login to check if everything is working fine or not. The frequency is high and I dont think its becaouse of the network. Can some one help with the trouble shooting
(4,102 Views)
Hi rajcerc,
Which protocol are you using to connect to your server? Are you using a database or database tools in your VI? Is it working for a specific amount of time before you get this error or is this happening on the first "iteration" of your code?
I found these two KnowledgeBase articles related to the error number you are getting - if they are not relevant, having more information regarding your overall VI's architecture, communication protocol as well as OS/LabVIEW versions would help.
1. What Does Error -2147467259 Mean When Connecting to an Oracle Database?
2. Error -2147467259 from Database VI on Windows 7 64-bit
Hope this helps!
Xavier
(4,084 Views)
