100kHz sinus AO generation with PCI-6731
HI
I'd like to generate a sinus at a frequency of 100kHz with this board.
But I don't know how to do this.
I've tried many way but It doesn't works.
For lower frequencies,  It works well but at this frequency the signal I obtain is poor.
any help?
(2,972 Views)
Hi Jules,
Whether for LabVIEW or CVI, you will find examples by using the NI Examples Finder, aviable under Help >> Find Examples... Did you just try this?
For analog generation, you can use for example Cont Gen Voltage Wfm-Int Clk.vi under LabVIEW.
In addition, the NI PCI-6731 has a maximum update rate of 1MS/s; this implies that one period of your sinusoidal waveform will be described by only ten points.
Cordially,
Message Edité par Mathieu R. le 12-19-2007 10:52 AM
(2,948 Views)
