2 channel continuous train of pulses generation and frequency can be changed on fly using PIC-6723
Hi
i am working on pci-6723 ,i would like to generate 2 channel continuous pulse generation , and frequency can be changed on fly .how can i use daqmx write in this case , kindly put a reply please
windows 2000 os
labview 7.1
Thanks and regards
rajesh
(2,968 Views)
Hi
windows 2000 os
labview 7.1
Thanks and regards
rajesh
(2,968 Views)
There are two great examples for what you are trying to do:
The first is the custom pulse generator vi. This example will use an analog output channel to write a custom pulse train.
The second example shows how to output data on the fly. You can combine these two examples to do exactly what you are trying to do.
I hope this helps, and have a Great Day!
(2,903 Views)
Information for these VI's can be found under File>>VI Properties>>Documentation.
George
(2,902 Views)
