Multifunction DAQ
-200284 Error on NI PCI 6251
Hello to all,
I have a problem of acquisition with a NI6251 card.
I manage to measure a frequence of 162KHz without problems, but I do not manage to measure 32KHz (on the same timer) and obtain an error -200284.
I use the same time acquisiton for the two measurement, 100ms.
Have you an idea of the problem?
(2,931 Views)
You have an -200284 error because you try to acquire too fast. The first acquisition is not complete and you run an other. Increase the time loop or the frequency
I advise you to read this: Why Do I Get Error -200284 from my DAQmx Read VI?
(2,906 Views)
