3.3 Vpp counter pulse generation
I have a question regarding counter pulse generation with 3.3 Vpp specification.
DAQmxErrChk (DAQmxWriteCtrFreq(pView->SweepRateHandle,1000,0,10.0,DAQmx_Val_GroupByChannel, pView->fUserFrequency, pView->fUserDutyCycle, NULL, NULL));
This function works fine but gives me 5 Vpp pulses.
Is there any function controlling amplitude conversion?
(2,795 Views)
Unfortunatly, the digital levels for almost every device (and every device with Counters that I know of) is determined by the hardware and can't be changed.  The easiest solution would either be a logic level shifter or a voltage divider.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(2,791 Views)
